Currently the Tables "Update" menu item is grayed out in JMP PRO 18
Is anyone running into the issue where the tables "update" menu item is grayed out and not usable?
Re: Currently the Tables "Update" menu item is grayed out in JMP PRO 18
What operating system are you using?  I have no issues on JMPPro 18.1.1 running on Windows 11
Win 11. I needed to restart the program twice to finally have the option working.
Do you have only one table open? I think it might be grayed out in that case as you cannot do "self-update" (you can do self-join though).
Yes two tables were opened multiple times. Had to restart the software twice to have the option work.
