wgoth
Creating a matrix of graphs
I have a question concerning layouts in JMP.  I am running equivalence tests between difference lasers (9 unique results) to ensure that they perform the same.  When I run the script, it returns a stack of about 36 different graphs in no particular order.  What I would like to do is something similar to what has been done with an R script before in which graphs were laid out in a matrix where corresponding equivalence graphs between the two lasers are easily located in the grid, like so:
Header 1Laser 1Laser 2Laser 3Laser 4Laser 5
Laser 1
Blank
L2 v L1 Equivalency GraphL3 v L1 Equivalency GraphL4 v L1 Equivalency GraphL5 v L1 Equivalency Graph
Laser 2L1 v L2 Equivalency GraphBlankL3 v L2 Equivalency GraphL4 v L2 Equivalency GraphL5 v L2 Equivalency Graph
Laser 3L1 v L3 Equivalency GraphL2 v L3 Equivalency GraphBlankL4 v L3 Equivalency GraphL5 v L3 Equivalency Graph
Laser 4L1 v L4 Equivalency GraphL2 v L4 Equivalency GraphL3 v L4 Equivalency GraphBlankL5 v L4 Equivalency Graph
Laser 5L1 v L5 Equivalency GraphL2 v L5 Equivalency GraphL3 v L5 Equivalency GraphL4 v L5 Equivalency GraphBlank
I've tried using the layout editor to to it manually, but this method is unreliable, ineffecient, and not easily replicable through scripting.  If anyone has any input on either an array graph script or means of scripting this to work, it would be much appreciate.
-Will
David_Burnham
You could try taking a look at the SheetBox display box
-Dave
David_Burnham
-Dave
wgoth
Thanks Dave, exactly what I was looking for!
mattf
Hi:
R Connection makes an easy example using the "lattice" package.
best,
-Matt
sas = SAS Connect();  // local PC SAS
SAS Submit("
libname temp 'c:/temp';
data temp.a;
     array laser (5) laser1-laser5;
     do x = 1 to 25;
         do i = 1 to 25;
           laser(i) - ranor(12345)*ranuni(x);
           end;
     output;
end;
drop x i;
run;
dt = sas << Import Data("temp.a");
SAS Disconnect();
Rcon = R Connect();
Rcon << send(dt);
Rcon << Submit("
     library(lattice);
     splom(dt[c(1,2,3,4,5)], main='Laser Data')
plot = RConnection << Get Graphics( png );
New Window ("Laser Plot", Picture Box( plot ) );
Rcon << Disconnect();
wgoth
We actually have a sript similar to this set up with R that we currently use but we're trying to switch over a lot of our analyses into JMP to make things more accessible to the rest of our associates, but thanks!
