FN
FN
Creating a formula column from a list ( JSL )
I want to create a simple formula for adding columns that are coming from a list.
The list can vary in the number of elements.
dt = Open( "$SAMPLE_DATA/Bands Data.JMP" );
col_list = {"varnish pct", "ink pct", "solvent pct" };
// expected formula (hard coded) dt << New Column( "mysum", Formula( Sum( :varnish pct, :ink pct, :solvent pct ) ) );
This solution works for a Col Sum.
https://community.jmp.com/t5/Discussions/Using-list-of-columns-in-formulas/td-p/405133
Re: Creating a formula column from a list ( JSL )
Here is one way of handling the issue
theList = {"varnish pct", "ink pct", "solvent pct"};
col_list = {"varnish pct", "ink pct", "solvent pct"};
Eval(
	Parse(
		"dt  << New Column( \!"mysum\!",
	Formula( " ||
		concat items( theList, "," ) || " ) )
Because formulas are open code, the actual is not evaluated as it is generated,  Therefore, it has to be a completed statement for JMP to process it properly.
FN
FN
The code works, but it was missing "Sum()".
If you edit the answer, I will accept it. Thanks :)
Eval(
	Parse(
	Formula( Sum(" ||
		concat items( col_list, "," ) || " ) )
I try to avoid using Eval(Parse()) when ever I can (even though it is fairly often the easiest method). Usually in cases like this (now) I build the expression and evaluate that expression inside the formula
// 1
sum_expr = Expr(Sum());
For Each({item}, col_list,
	Insert Into(sum_expr, Name Expr(As Column(dt, item)));
//show(Name Expr(sum_expr));
Eval(EvalExpr(
		Formula(Expr(Name Expr(sum_expr)))
// 2
col_listing = Transform Each({item}, col_list,
	Name Expr(As Column(dt, item));
Eval(Substitute(
	Expr(dt << New Column( "mysum", Formula(_sums_))),
	Expr(_sums_), Substitute(col_listing, Expr(List()), Expr(Sum()));
