BHarris
Create duplicate heat-maps with different summary statistics in Graph Builder
Given Big Class and this plot:
Graph Builder(
	Size( 574, 613 ),
	Graph Spacing( 20 ),
	Variables(
		X( :sex ),
		X( :sex ),
		Y( :age ),
		Color( :height, Summary Statistic( "Min" ) )
	Elements( Position( 1, 1 ), Heatmap( X, Y, Legend( 4 ) ) ),
	Elements( Position( 2, 1 ), Heatmap( X, Y, Legend( 5 ) ) )
Is there a way to make the left plot use the "Mean" summary statistic and the right plot to use "Min"?
I tried adding another Color() specification but it doesn't seem to work in JMP 17.
Level XII
Re: Create duplicate heat-maps with different summary statistics in Graph Builder
-> add another color
Works with JMP 17 (.2)
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
Graph Builder(
	Size( 574, 613 ),
	Summary Statistic( "Median" ),
	Variables(
		X( :sex ),
		X( :sex ),
		Y( :age ),
		Color( :height, Summary Statistic( "N" ) ),
		Color( :height, Summary Statistic( "Max" ) )
	Elements( Position( 1, 1 ), Heatmap( X, Y, Color( 1 ), Legend( 4 ) ) ),
	Elements( Position( 2, 1 ), Heatmap( X, Y, Color( 2 ), Legend( 5 ) ) )
BHarris
Excellent, that worked!  I think I was missing the extra X variable when I added the color spec.  It would be nice if GB supported this with the UI, but it already does so much...
Here's the final script I was looking for:
Graph Builder(
	Size( 934, 824 ),
	Show Title( 1 ),
	Variables(
		X( :sex ),
		X( :sex ),
		X( :sex ),
		Y( :age ),
		Color( :height, Summary Statistic( "Min" ) ),
		Color( :height, Summary Statistic( "Mean" ) ),
	Elements(
		Position( 1, 1 ),
		Heatmap( X, Y, Color( 1 ), Legend( 1 ), Label( "Label by Value" ) )
	Elements(
		Position( 2, 1 ),
		Heatmap( X, Y, Color( 2 ), Legend( 2 ), Label( "Label by Value" ) )
	Elements(
		Position( 3, 1 ),
		Heatmap( X, Y, Color( 3 ), Legend( 3 ), Label( "Label by Value" ) )
		Dispatch(
			"graph title",
			TextEditBox,
			{Set Text( "Age vs. Sex, Colored on Height -- Min, Mean, Max" )}
		Dispatch(
			"400",
			LegendBox,
			{Legend Position( {1, [0], 2, [-1], 3, [-1]} )}
What I did was to
  1. Use Tables=>Summary to create a new table with the mean and min statistics grouped by Sex and Age
  2. Use Tables=>Stack to stack the mean and min columns
  3. Run Graph Builder
names default to here(1);
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
// Data table summary
// → Data Table( "Summary of Big Class grouped by age, sex" )
Data Table( "Big Class" ) << Summary(
	Group( :age, :sex ),
	Mean( :height ),
	Min( :height ),
	Freq( "None" ),
	Weight( "None" ),
	statistics column name format( "stat" ),
	output table name( "Summary of Big Class grouped by age, sex" )
// Stack data table
// → Data Table( "Stack of Summary of Big Class grouped by age, sex (Mean, Min)" )
Data Table( "Summary of Big Class grouped by age, sex" ) <<
Stack(
	columns( :Mean, :Min ),
	Output Table( "Stack of Summary of Big Class grouped by age, sex (Mean, Min)" )
Graph Builder(
	X Group Edge( "Bottom" ),
	Variables( X( :sex ), Y( :age ), Group X( :Label ), Color( :Data ) ),
	Elements( Heatmap( X, Y, Legend( 4 ) ) )
Another option is to create two graph builder reports and place them side by side in a custom report new window. You might want to re-title the graphs so it is clear that one is colored Min and Max. Here is a simple example:
hm1 = expr( dt << Graph Builder(
	Size( 235, 613 ),
	Variables(
		X( :sex ),
		Y( :age ),
	Elements( Heatmap( X, Y, Legend( 1 ) ) ),
hm2 = expr( dt << Graph Builder(
	Size( 235, 613 ),
	Variables(
		X( :sex ),
		Y( :age ),
new window( "Two Heat Maps",
	h list box( hm1, hm2 )
-Scott
At the risk of over-engineering this solution, you could generalize this for a list of stats.
statList = { "Mean", "Median", "Mode", "Min", "Max", "Range", "Median", "Std Dev" };
hm_fxn = function( { STAT },
		Size( 200, 300 ),				// Adjust size based on number of heatmaps
		Variables(
			X( :sex ),
			Y( :age ),
			Color( :height, Summary Statistic( STAT ) )
			Dispatch( {}, "Graph Builder", OutlineBox,
			{Set Title( "Color by " || STAT ), Image Export Display( Normal )}
new window( "Heat Maps",
	outline box( dt << get name || " Heat Maps",
		lub = line up box( n col( 4 ) )	// Adjust n col() for number of heatmaps per row
for each( { s }, statList,
	lub << append( hm_fxn( s ) )
-Scott
Level XII
Graph Builder(
	Size( 574, 613 ),
	Variables(
		X( :sex ),
		X( :sex ),
		Y( :age ),
BHarris
Graph Builder(
	Size( 934, 824 ),
	Show Title( 1 ),
	Variables(
		X( :sex ),
		X( :sex ),
		X( :sex ),
		Y( :age ),
	Elements(
		Position( 1, 1 ),
	Elements(
		Position( 2, 1 ),
	Elements(
		Position( 3, 1 ),
		Dispatch(
			"graph title",
			TextEditBox,
		Dispatch(
			"400",
			LegendBox,
