robot
Create Invisible Journal
I have a script where I create a journal that serves only as a container for other platform results before it is saved as a JPG and closed.  Is it possible to create a journal using the invisible option?  I have not been able to get it to work.  I am using JMP10.
// These do not work...
jrn1 = New Window( "Graph Results", <<Journal, Invisible );
jrn2 = New Window( "Graph Results", <<Journal, <<Invisible );
jrn3 = New Window( "Graph Results", <<Invisible, <<Journal );
jrn4 = New Window( "Graph Results", Invisible, <<Journal );
jrn5 = New Window( "Graph Results", Invisible ) << Journal;
jrn6 = New Window( "Graph Results", <<Journal ) << Invisible;
michaelhaslam_p
Re: Create Invisible Journal
Robot,
There is really no need to have an invisible option for New Window.  The purpose of New Window is to "display" a visible window.  You can make a display tree outside of New Window and simply save a picture of it to accomplish your goal.  Here I have used image type PNG, but you could easily use JPG.  The Platform command evaluates and creates a display box for use in your display tree.
In JMP 9 or later:
// Make and saving a display tree  outside of New Window
// Open the table and assign it a reference
dt = Open (Convert File Path("$Sample_Data") || "Big Class.jmp", invisible);
// Run the analysis and create a display box using Platform()
db1 = Platform(dt, Bivariate( Y( :height ), X( :weight ) ));
// Create the display tree you want
Display Tree = VListBox(
OutlineBox("My Outline",
  TextBox 1 = TextBox("Here is my analysis of Big Class."),
  db1
//  Save the display tree as a picture
Temp = Display Tree << Save Picture(Convert File Path("$Documents") || "Temp.png");
//  You can now close the datatable
Close(dt,Nosave);
Michael Haslam
michaelhaslam_p
Robot,
In JMP 9 or later:
  db1
Close(dt,Nosave);
Michael Haslam
robot
Hi Michael,
I am unable to run your script without my JMP10 crashing at the
step.  I have tried changing the file format to .jpg, but still without success.  Perhaps this is due to differences between JMP9 and JMP10.  I will play around with the syntax as I have time.
Thanks for the input.
michaelhaslam_p
Robot,
I just ran the code in 9.0.3 and 10.0.2.  Both ran fine.  What version are you using?
Michael
robot
Hi Michael,
Sorry for the very late reply to your answer.  Your solution works.  Thanks for the help.
Rob
