Cox proportional hazards
Hi!
I am very new to this forum and to JMP&statistics in general. I would appreciate if somebody could advise me on a following issue:
I am analyzing whether certain factors (A, B, C etc - all of them are continuous variables) are predictors of a disease (X) incidence. I have 2 independent groups of patients (group 1 - healthy, and group 2 - those ended up with a disease). I need to adjust those factors for age, gender, race etc. When I go to Analyze->Reliability and Survival->Fit Proportional hazards I am a little bit puzzled what goes where. Could you please advise?
I apologize those of you who will see this question as a very basic one. I was trying to look it up online but could not fins a definite answer anywhere
I will greatly appreciate your help!
Casandra
jiancao
Re: Cox proportional hazards
In this Mastering JMP WebEx, I showed how to fit a Cox's PH model to the data similar to yours. This is the link to the recordings: Advanced Mastering JMP: Analyzing Survival Data | JMP
Hope it helps.
jiancao
Hope it helps.
triunk
Hi Jian
Does Jmp pro 13.2 have the option for time-dependent or time-varying covariates. I tried to find some info but I could not.
Hope you can shed more light on my question
Thank you
Chris
Phil_Kay
It may be that the proportional hazards is not the appropriate approach here. You should learn from the Mastering webex that this method is for when you have a time-to-event outcome, such as time-to-death. These methods also deal with censoring. For example, where you have subjects at the end of the observed time period who have still not experienced the event.
It sounds like in your situation all you know about the outcome for the subject is a binary: healthy or with-disease (1 / 2). So this would be handled with a logistic regression.
