Countif equivalent?
I am trying to find a JMP formula function equivalent to Excel’s Countif function, that points to a column and returns the number of rows that are the same as the value in the current row, as you would get if you did a Summary on that row.
In other words, if I have a 1000-line table, and column Color is set to "Purple" in 27 rows, I want a formula for a new row that returns 27 for those rows (and the applicable value for the other rows)
(I’m sure this is in here, but **bleep** if I can find it)
JMP 17, macOS
11 REPLIES 11
Craige_Hales
Re: Countif equivalent?
Close, I think. I was never in that C++ code, but I believe on the very first call (typically for row 1) it preprocesses all the rows to cache all the possible by-value answers. Then all subsequent rows are answered from that by-value cache. (Without the cache it would be an order(N^2) time for N rows, with the cache just order(N) - linear time.)
Craige
hogi
Level XIII
@Audrey_Shull If you plan to add @jthi 's example in a future version of Scripting Index or Online Help , please also add a paragraph about the magic of
https://community.jmp.com/t5/Discussions/JMP-equivalent-of-Excel-s-COUNTIF-function/m-p/783500/highl...
