SpannerHead
Count the Most Frequently Occurring Item in a Column
I want to readily identify the item that most frequently occurs by row count in a JMP column.  I can easily determine the unique entries, how best can I get a count from there?
summarize( lotz = by(:LOT));
Slán
SpannerHead
Re: Count the Most Frequently Occurring Item in a Column
Summary Platform is what I generally use for this (how I use it depends on the use case: ties, do I need the count, how should missing values be handled and so on)
dt_summary = dt << Summary(
	Group(:sex),
	Freq("None"),
	Weight("None"),
	output table name("res"),
	Private
// Using Loc Max
max_row = Loc Max(dt_summary[0, "N Rows"]);
max_val = dt_summary[max_row, 1];
show(max_val);
// Sorting
dt_summary << Sort(By(:N Rows), Replace Table, Order(Descending));
my_val = dt_summary[1, 1];
show(my_val);
Close(dt_summary, no save);
Also just using Mode function might be enough
val = Mode(dt[0, "sex"]);
And there are plenty of other options (like you can see in this thread already).
SpannerHead
I made this tweak and I appear to be successful.
full_proc_rows = dt << get rows where( !Is Missing( :process ) );
proc_val = Mode(dt[full_proc_rows, "process"]);
Slán
SpannerHead
9 REPLIES 9
mmarchandFSLR
This takes into account the possibility of a tie for most frequent:
dt = Data Table( "Big Class" );
dt << Add Rows( {:name = "BARBARA", :age = 13, :sex = "F", :height = 100, :weight = 79} );
Summarize( namez = By( :name ) );
numberz = Transform Each( {v, i}, namez, Length( Where( dt, :name == v ) ) );
max_num = Max( numberz );	//2
big_name = namez[Where( numberz == max_num )];	//{"BARBARA", "ROBERT"}
SpannerHead
This is a good looking script but for some reason, it gives numberz as 5 for everything.
Thanks
Slán
SpannerHead
The Distribution Platform will give you a Mode.
It is under the red triangle for the Summary Statistics Paragraph.  Just select
     Customize Summary Statistics
and then select the additional statistics you want displayed
Level XIII
If you prefer a column formula:
Names Default to Here(1);
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
New Column( "N by age",
	Formula( Col Number( 1, :age ) )
and to identify the winner:
New Column( "max N by age",
	Formula( Col Number( 1, :age ) == Col Max( Col Number( 1, :age ) ) )
Alternatively, you can use Summarize:
Summarize( namez = By( :age ), cnt = count(:age) );
or tables/summary:
Data Table( "Big Class Families" ) << Summary(
	Group( :age )
SpannerHead
The summarize suggestion is a good one.  It gives me 2 dissociated lists.  If I could somehow get that to be an associative array, I could use the max "cnt" value to identify the associated "namez" value.
Slán
SpannerHead
SpannerHead
I did this and it seems to work.
Summarize( namez = By( :LOT ), cnt = count(:LOT) );
keys = namez;
values = Eval List(cnt);
AA = Associative Array(keys, values);
For( g = 1, g <= N Items( AA ), g++,
    If(values[g] == Max(cnt), mainLOT = keys[g]));
Slán
SpannerHead
	Group(:sex),
	Freq("None"),
	Weight("None"),
	Private
// Using Loc Max
show(max_val);
// Sorting
show(my_val);
SpannerHead
Jarmo
Mighty!  This does the trick and it includes non numeric values.  The only refinement I need is to have it ignore missing data somehow?
val = Mode(dt[0, "process"]);
Slán
SpannerHead
SpannerHead
Slán
SpannerHead
