I would maybe write this as SQL query, but it can be also done in JSL. Below is one possible option (there are many simpler and more complicate ones)
dt = New Table("Project Status",
Add Rows(5),
New Column("Project", Character, "Nominal", Formula("Project " || Char(Row()))),
New Column("Start Date", Numeric, "Ordinal", Format("m/d/y", 12), Formula(Date Increment(Today() - In Days(Row() * 10), "Day"))),
New Column("End Date", Numeric, "Ordinal", Format("m/d/y", 12), Formula(Date Increment(Today() + In Days(Row() * 10), "Day")))
dt << Run Formulas;
:Start Date << Delete Formula;
:End Date << Delete Formula;
// Add monthyear column based on Start Date
new_col1 = dt << New Column("MonthYear1",
Numeric,
"Ordinal",
Format("m/y", 12),
Formula(Date DMY(1, Month(:Start Date), Year(:Start Date)))
new_col2 = dt << New Column("MonthYear2",
Numeric,
"Ordinal",
Format("m/y", 12),
Formula(Date DMY(1, Month(:End Date), Year(:Start Date)))
// calculation should be based on min date and max date found from dataset in my opinion
// not based on the found values, but this is easier so I'll use this
date_months = Associative Array(new_col1);
date_months << Insert(Associative Array(new_col2));
dt << Delete Columns({"MonthYear1", "MonthYear2"});
aa_results = Associative Array();
For Each({month_start}, date_months << get keys,
// last day of month
max_day = In Days(Days In Month(Year(month_start), Month(month_start))) + month_start - Time Of Day(month_start);
// some logic to get projects
r = dt << Get Rows Where((:Start Date <= month_start & :End Date >= month_start) | (month_start <= :Start Date < max_day));
aa_results[month_start] = N Items(r);
dt_results = New Table("Results",
New Column("MY", Numeric, Continuous, Values(aa_results << get keys)),
New Column("ProjInProg", Numeric, Continuous, Values(aa_results << get values)),
