aandw
Count Sum of Repeat Occurrences By Specified Variable?
I would like to create a count sum formula which sums the number of occurrences of a value by a specified column variable.
I want to know by a specified column variable value (i.e. Month) how many times did the same value appear in the column of interest.
Example:  Sum Type of Fruit By Month
New Column ( "Count_Fruit_Mo",
                        numeric,
                         continuous,
                         // formula or command TBD
MONTHFRUIT
1
ORANGE
1
ORANGE
1APPLE
2ORANGE
2APPLE
// a Summation command appears to function for the entire column, but does not allow specification by another column variable.
// formula( Summation( i = 1, N Row(), :FRUIT == :FRUIT))
//  ORANGE = 3; APPLE = 2
I'm hoping to generate,
:Month = 1;  :Fruit = "ORANGE";  :Count_Fruit_Mo = 2
:Month = 2;  :Fruit = "APPLE";  :Count_Fruit_Mo = 1
ms
Super User (Alumni) ms
Re: Count Sum of Repeat Occurrences By Specified Variable?
Consider using the function Col Number() with optional By-arguments:
Col Number(Row(), :MONTH, :FRUIT)
ms
aandw
Thank you.  Very helpful.
lloyd_tripp
Thanks MS,
This helped me count up duplicate columns that I know are replicate measurements. It's very fast for a 4000 row table we have. Now I can weight columns appropriately by the amount of replicate measurements are taken.
pmroz
You can use the SUMMARIZE command:
dt = New Table( "Month-Fruit",
     Add Rows( 5 ),
     New Column( "Month", Numeric, Continuous,
           Format( "Best", 12 ), Set Values( [1, 1, 1, 2, 2] )
     New Column( "Fruit", Character, Nominal,
           Set Values( {"ORANGE", "ORANGE", "APPLE", "ORANGE", "APPLE"} )
summarize(f = by(:month, :Fruit), c = count);
show(f, c);
f = {{"1", "1", "2", "2"}, {"APPLE", "ORANGE", "APPLE", "ORANGE"}};
c = [1, 2, 1, 1];
The way to interpret the output is that there are 4 unique combinations of month and fruit.
For month 1, APPLE the count is 1
For month 1, ORANGE the count is 2
For month 2, APPLE the count is 1
For month 2, ORANGE the count is 1
jimloughlin
I get an error.  Here's the log:
Name Unresolved: f{5} in access or evaluation of 'f' , f/*###*/
In the following script, error marked by /*###*/
Add Rows( 5 ),
Numeric,
Continuous,
Character,
Nominal,
dt << Summarize( f = by( :month, :Fruit ), c = count );
Show( f/*###*/, c );
c = [1, 2, 1, 1];
Jim Loughlin
Loughlin Consulting
pmroz
Sorry - I removed "dt <<" and it's working.  The post has been corrected above.
