Marco2024
Could JMP show in a single graph a sensitivity analysis and the probability of occurrence of a result?
Hello Community!
Attached is the script "Hogi chart calculates risk and probability", an excellent work by HOGI ... which calculates the risks and probabilities of occurrence of an input or multiple inputs (x), of an output or multiple outputs (Y) or their combination in a table. For example:
Would it be possible to expand the capacity of the script to make a sensitivity analysis of the inputs (x) of the table and show a graph with the most important and least important inputs (x), the Mean, Standard Deviation, Asymmetry, Kurtosis ... etc? ... for example:
Greetings,
Marco
0 REPLIES 0
