Unfortunately, @MRB3855 , the link that you provide does not perform the calculations correctly and does not use the proper covariance formula.
The covariance formula is typically divided by n-1 rather than just n. The calculations are also incorrect as the last observation for (Y-Y bar) should be a -12, and the author just uses 12.
For the simple four observation example in the article, the correct correlation is 1. The covariance should be 26.67.
Dan Obermiller
