Pandasgroupby
Copy paste histogram and nominal quantile plot
I used to be able to copy and paste histogram and CDF plot without any problem. But recently I started to see the pasted histogram changed dramatically. Could someone tell me what's wrong ?
The operation I did was right click at the 2nd bottom histogram and choose "Edit" "Copy Frame Contents". Then move to the first histogram and right click and pick "Edit" "Paste Frame Content". As you can see, the cyan colored the distribution is over 1.
My jmp version is 17.0.0.
Thank you,
Jane
Byron_JMP
Re: Copy paste histogram and nominal quantile plot
That's super weird, I wouldn't expect that to happen. If its reproducible, I'd send a note to [email protected]
