Jackie_
Change Gradient Max with Slider box
Is there a way to vary the Max value of the gradient using the slider box?
dt = Open( "$SAMPLE_DATA/Wafer Stacked.jmp" );
sliderValue = .6;
New Window( "",
	H List Box(
		Panel Box( "Slider Box",
			tb = Text Box( "Gradient Maxium: " || Char( sliderValue ) ),
			sb = Slider Box( 0, 10, sliderValue, tb << Set Text( "Value: " || Char( sliderValue ) ) )
		H List Box(
			Graph Builder(
				Size( 592, 569 ),
				Show Control Panel( 0 ),
				Variables( X( :X_Die ), Y( :Y_Die ), Color( :Defects ) ),
				Elements( Heatmap( X, Y, Legend( 5 ) ) ),
					Dispatch(
						"400",
						ScaleBox,
						{Legend Model( 5, Properties( 0, {gradient( {Min Lightness( 0 ), Width( 12 )} )}, Item ID( "Defects", 1 ) ) )}
Re: Change Gradient Max with Slider box
You can
dt = Open("$SAMPLE_DATA/Wafer Stacked.jmp");
sliderValue = 0.6;
nw = New Window("",
	H List Box(
		Panel Box("Slider Box",
			sb = Slider Box(0, 10, sliderValue,
				vals = [.] || Matrix(sliderValue);
				Eval(EvalExpr(
					item << Set Properties({gradient({Scale Values(Expr(vals))})})
		H List Box(
			gb = dt << Graph Builder(
				Size(592, 569),
				Show Control Panel(0),
				Variables(X(:X_Die), Y(:Y_Die), Color(:Defects)),
				Elements(Heatmap(X, Y, Legend(5))),
					Dispatch({}, "400", ScaleBox,
						{Legend Model(
							5,
							Properties(
								0,
								{gradient({Min Lightness(0), Width(12)})},
								Item ID("Defects", 1)
server = gb << Get Legend Server;
item = server << Get Legend Item(5, 1);
You can
sliderValue = 0.6;
nw = New Window("",
	H List Box(
				Eval(EvalExpr(
		H List Box(
				Size(592, 569),
						{Legend Model(
							5,
							Properties(
								0,
I believe you can do what you want by changing the Scale Values using a Set Gradient Scale Values message.  See the Scripting Index for description and examples.
