nadershakerin0
Converting Military Time Format (hhmm) to Time Format (hh:mm)
I need to convert military time in the hhmm format, e.g. 1432 or 725 to hh:mm format e.g. 14:32 to 7:25.  Is there a simple formula that can make the conversion, or should I use a script for it?  Thanks.
Re: Converting Military Time Format (hhhh) to Time Format (hh:mm)
Here is a different way of doing the same thing that Bryon is showing.  My version goes directly to a numeric time value, rather than creating a character value that is then input.
// Create a sample data table with some Military times.....
// The column can be either numeric or character...the conversion
// formula handles both
dt = New Table( "Untitled 3", Add Rows( 2 ), New Column( "Military", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [1421, 923] ) ) );
// The wait() functions are just there to add a dramatic affect :)
Wait( 2 );
// Add a new column to hold the converted times
// Use a time format since the conversion will create
// a value which is the number of seconds since midnight
dt << New Column( "time", Numeric, "Continuous", Format( "hr:m", 12 ) );
Wait( 2 );
// Run across all rows and do the conversion
// The formula will work as a column formula by just removing
// the ":time="
For Each Row(
       :time = Num( Substr( Char( :Military ), -2 ) ) * 60 +
              Num( Substr( Char( :Military ), 1, (Length( Char( :Military ) ) - 2) ) ) * 3600
11 REPLIES 11
Byron_JMP
There is likely a simpler way to do this; however, this works pretty well.
Step 1
Repeat( "0", 4 - Length( Char( :Start ) ) ) || Char( :Start )
Makes the staring number into a 4 digit character padded with zeros (this is handy for zip codes too)
Step 2
Left( :Step 1, 2 ) || ":" || Right( :Step 1, 2 )
Inserts a colon between the hours and minutes
Step 3
Format( Informat( :Char 24 hr Time, "h:m" ), "h:m" )
This formula takes the character 24 hr time and turns it into the number of seconds after midnight, then it turns the seconds into 12 hour time.
Informat evaluates a character string and returns a number
format evaluates a numeric strings and returns a character
Start Step 1 Step 2 Step 3
3 0003 00:03 12:03 AM
30 0030 00:30 12:30 AM
1130 1130 11:30 11:30 AM
1830 1830 18:30 6:30 PM
or you could do it all in one "simple" step with one formula
Format(
	Informat(
		Left( Repeat( "0", 4 - Length( Char( :Start ) ) ) || Char( :Start ), 2 ) || ":" ||
		Right( Repeat( "0", 4 - Length( Char( :Start ) ) ) || Char( :Start ), 2 ),
		"h:m"
	"h:m"
I keep a collection of fierce formulas that get recycled for special cases.
nadershakerin0
Re: Converting Military Time Format (hhmm) to Time Format (hh:mm)
Byron, thank you very much for your guidance.  Your proposed method works; however, it keeps the variable in character state.
I have saved your script for future special cases!
Wait( 2 );
Wait( 2 );
// the ":time="
For Each Row(
nadershakerin0
Jim, your solution worked perfectly. I like how everything remained in the numeric form. Thank you very much!
Madwolf
Hi Jim,
How do I use this script? What are the variables that I needed to change?
Then name of the dataset is "transaction_data" and the name of the column that resides the military time is "DAY" (transaction_data:DAY)
So, how should I replace these 2 variables into you script and run?
Sorry for such a noob question.
Madwolf
I posted your code, into the formula section of the new field, changed the field to my dataset column name, and it works perfectly!
Num( Substr( Char( :Military ), -2 ) ) * 60 + Num(
) * 3600
Thank you so much!
Madwolf
I attempted to use this code to convert a string into a time format (hh:mm)
) * 3600
However, I realised if the string is only 2 digits, it won't get converted. For instance if it is 26, it won't be converted to 12:26am. However, a 3 digit string works fine (100 becomes 1:00am)
How is that so?
My first question is, if the length of the input time value is less than 4 characters long, should one assume there are zeros (0) that are missing from the left side of the military time?  If this is the case, I propose the solution below;  It pads the value with leading zeros and then performs the conversion.
standard = Substr( "00", Length( Char( :Military ) ) - 1 ) ||
Char( :Military );
Num( Substr( Char( :standard ), -2 ) ) * 60
+Num(
	Substr(
		Char( :standard ),
		1,
		(Length( Char( :standard ) ) - 2)
) * 3600;
Madwolf
It works! Thank you so much. I learnt so much just by looking at the formulas you proposed!
