Convert decimal to Binary
justvince
I need to convert Columns of data (decimal) to binary (8 bit) , then concantenate say the 4 LSB to the next column of data with the 4 MSB.  Is there a way to at least convert decimal data to binary in JMP?
Duane_Hayes
Staff (Retired)
Re: Convert decimal to Binary
As previously stated:
Hi - can you adapt the following to do what you need?
// Function to convert an integer into any positive base up to hexadecimal;base = Function( {n, nbase}, {default local},
       ndash = "";
       digits= "0123456789ABCDEF";
     While( n > 0,
              remainder= Mod( n, nbase );
              newdigit= Substr( digits, (1 + remainder), 1 );
              ndash= newdigit || ndash;
              n= (n - remainder)/ nbase;
ndash;
// Print out a few numbers to show it working in binary;
For( i = 1, i <= 32, i++, Show( Char( i ) || " = " || base( i, 2 ) ) );
// Or create some new columns in a data table and fill them;
dt = New Table( "Number Bases", New Column( "N", numeric, values( Index( 1, 32 ) ) ) );
numberbase = {2, 3, 8, 10, 12, 16}; // Some familiar number bases;
For( i = 1, i <= N Items( numberbase ), i++,
     k= numberbase[i];
     dt<< New Column( "Base "|| Char( k ), character );
     For( j = 1, j <= N Row( dt ), j++,
     Column( dt, ("Base "|| Char( k )) )[j] = base( j, k ) );
// End of program;
And:
No problem - an extra "if" clause will treat n=0 as a special case:
base = function({n, base}, {default local}, ndash = ""; digits = "0123456789ABCDEF";
if(n > 0, while(n > 0, remainder = mod(n, base); newdigit = substr(digits, (1 + remainder), 1);
ndash = newdigit || ndash; n = (n - remainder) / base), ndash = "0"); ndash);
(I'm assuming that n is a non-negative integer, and that base is a positive integer.)
Duane Hayes
       ndash = "";
     While( n > 0,
ndash;
     k= numberbase[i];
// End of program;
justvince
It is a start.  But it appears the function base will not convert a zero to binary 0,
Duane_Hayes
Staff (Retired)
       ndash = "";
     While( n > 0,
ndash;
     k= numberbase[i];
// End of program;
And:
Duane Hayes
