reginado
Convert CSV file to JMP file
would you know how to convert CSV file into JMP file?
Thanks,
RD
Re: Convert CSV file to JMP file
Select File > Open.
Navigate to data folder.
Select CSV file.
Click Open.
reginado
Thanks Mark. I need to do this outside of JMP, so that users can import JMP file. Other format is not for this specific case acceptable. So my original question is - how to convert csv into jmp file outside of JMP.
See Help > Books > Using JMP for more information about importing data stored in foreign file formats.
