Created:
Apr 16, 2021 02:17 PM
| Last Modified: Jun 10, 2023 1:44 PM(3757 views)
In the EWMA chart from the Legacy control charts, it is possible to specify both the weight and the K values (multiplier for control limits). Changing the K value is a typical step when parametrizing an EWMA chart. In the new EWMA control chart in JMP16, how can I change the K value?
Hi everyone - i'd like to state here that this option has in fact been implemented by the development team in the upcoming major JMP release, JMP 17. JMP 17 will be available in the fall of 2022. A K Sigma option is now available in the red triangle menu. By default, K Sigma is set to 3.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '377402' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '377402') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '377402') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
