Arkawa
Control chart limits set up by phase (not normal distribution)
Hi all,
I would like to know if it is possible to set up control limits by phase once data are not normally distributed, thus having calculated them by quantile estimation and entered them manually. I know that the CL are automatically set up by phase using the normal distribution by default. But I did not succeed either to fix the distribution for control chart in column properties (it only works for capability) or entered it manually per phase (currenlty I use the reference lines but it crosses out the graph and I have to delete the exceeding by paint :/). If not, should I transform the data in column by the distribution observed and set up control limits normally ?
Thank you very much for your support !
Best regards
Arkawa.
Re: Control chart limits set up by phase (not normal distribution)
Here is a blog post that details how to set historical control limits for each phase.
Creating a phase control chart with historical limits for each phase - JMP User Community
Arkawa
Hi all,
Tonya, your post is amazing ! Very helpful ! However, the approach was simplified with JMP 15.
Generate the I control chart with the phases containing the 3sigma limits within data normally distributed. Go to the hot spot of the control chart and save limits into data table. In this data table we already have the column formula that you shared in your post. You just have to change each LCL and UCL as you have determined before (ex: quantile estimation). You save the file (ex Force limits). When you return on your control chart you go to the hot spot, then get limits and finally select the data table Force limits. Control limits by phase are therefore automatically set-up from the file and western electric process rules are applicable :).
Thank you !
Arkawa
statman
Not sure I understand completely, but there is no assumption of normally distributed data for control charts to be effective (See Wheeler and Shewhart). https://www.spcpress.com/pdf/DJW088.pdf
Having said that control charts in JMP subgroups can be set  by constant size or by Sample Label.
Arkawa
Hi, thats why I proposed the quantile estimation to be applied on the data distribution observed (after data cleaning).
Thanks !
Arkawa
Arkawa
Hi all,
Thank you !
Arkawa
Yes, this blog post has the following comment "JMP 13.1 and above will create this table for you if you click on the red triangle next to Control Chart Builder and choose Save Limits -> in New Table."  The steps that came after that statement were for JMP 13.0 and below.
