PersuasionCamel
Control Charts use saved Control limits
I hope you are doing well.
I have a question about the control limits saved in a data table. Is there any way to propose a textbox to the user showing all the control limits saved in a data table. And the user can put a checkmark to the one to use for the Control chart ?
Thank you very much for your answer and have a nice day,
Jean
Re: Control Charts use saved Control limits
Do you mean Control Limits column properties? This could be done with scripting but I'm not sure if you can "disable" the column properties. So you might have to save them to other table/table variable/variable and then add/remove them as needed.
PersuasionCamel
Ah yes, I mean: my question was how can I use the control limits (saved in an other table) with a dynamic textbox ?
Here is fairly simplified example how you could do it.
// https://www.jmp.com/support/help/en/16.2/#page/jmp/example-of-control-limits.shtml#ww1447886
dt = Open("$SAMPLE_DATA/Quality Control/Steam Turbine Historical.jmp");
dt_specs = New Table("Turbine Specs",
	Add Rows(3),
	New Column("Measurement", Character, Nominal, Values({"Fuel", "MW", "Cool Temp"})),
	New Column("LCL", Numeric, Continuous, Values([200000, 19, 53])),
	New Column("UCL", Numeric, Continuous, Values([250000, 22, 55])),
	invisible
possible_measurements = Column(dt_specs, "Measurement") << get values;
nw = New Window("Select Limits", << modal, << return result,
	V List Box(
		Text Box("Select measurements to use predefined specs limits for:"),
		cb_selections = Check Box(possible_measurements, << Set(1))
aa_specs = Associative Array();
For Each({selection_idx}, nw["cb_selections"],
	aa_specs[possible_measurements[selection_idx]] = dt_specs[selection_idx, {"LCL", "UCL"}];
obj = dt << Control Chart Builder(
	Show Control Panel(0),
	Variables(Y(:Fuel)),
If(Contains(aa_specs, "Fuel"),
	Eval(EvalExpr(
		obj << Chart(Position(1), Set Control Limits({
			LCL(Expr(aa_specs["Fuel"][1])), UCL(Expr(aa_specs["Fuel"][2]))
Write();
How you should do it depends on your starting measurement data, control limit table, how you want to display control charts, how dynamic and robust you need this to be, your scripting skill level and so on
