khill
Control Charting with transactional recordset
I'm trying to understand if JMP supports a control chart graph directly from transactional data without first having to create a summary table.
The JMP sample data table called Washers contains 15 records showing the count of defects per lot size of 400. Taking one step back there may have existed a data table of 6000 records (15x400) where each record contained the defect count of 1 or 0. Would JMP be able to create a p control chart from this original data set without first creating the washers.jmp summary table?
Thanks,
John
0 REPLIES 0
