aumair
Contains function help
I am a JMP/JSL rookie. I was just experimenting if I can get th char number of first "a"  in the 'name' column of Big Class.jmp.
I am writing this in formula: Contains(:name, "a", 1), and the output is 0 in all the rows. Could someone please point out the problem?:)
Thanks!
Ahmad
Re: Contains function help
Character strings in JMP are case sensitive.  The correct formula is:
contains(:Name,"A")
contains(:Name,"A")
aumair
Thanks a lot!!!
contains(:Name,"A")
