pmroz
Confidence Intervals using a Binomial Distribution
I need to calculate 95% confidence intervals for the reporting fraction of adverse events at different time intervals. I'd like to use the "Exact Binomial Confidence Interval".
The link below shows how to do it using Excel; is there a comparable way to do this in JSL?
http://www.itl.nist.gov/div898/handbook/prc/section2/prc241.htm
Thanks!
ms
Super User (Alumni) ms
Re: Confidence Intervals using a Binomial Distribution
Here is an example of the nonlinear approach. The script below creates a data table with same data as in the Excel example. Run the table script to calculate the confidence limits.
(I first tried a neat solution that included the nonlinear platform (invisibly) in a column formula to enable automatic calculation. It worked, but not always as JMP sometimes got stuck inside an apparently infinite loop.)
12 REPLIES 12
It looks like that is using the Clopper-Pearson Exact CI. Here is what I have used for calculating the upper confidence interval for alpha. Unfortunately, the theory on how it was derived has faded from my memory.
Clopper Pearson Exact Upper Bound
(1 + (:Total - :Fail) / ((:Fail + 1) * F Quantile(
1 - :alpha,
2 * (:Fail + 1),
2 * (:Total - :Fail)
))) ^ (-1)
mpb
mpb
There are a couple of ways to imitate the Excel example directly using the JMP Binomial Distribution function. One way is to create a column with that formula and other columns for the independent variables and use the Profiler to achieve the target right hand side by varying the proportion p. The other way is to set it up as a nonlinear fit using p again to achieve the target right hand side. They both work.
ms
pmroz
Thank you all for your answers. MS your solution worked when I pulled the New Script section out and ran it separately (in JMP 8.0.2 and 9.0.0).
pmroz
MS is there a way I can generalize your solution for a table full of
values?  For example:
style="font-family: Courier New,Courier,monospace; font-weight: bold; text-decoration: underline;">Preferred
Term
Count     Total
Fraction
style="font-family: Courier New,Courier,monospace;">
style="font-family: Courier New,Courier,monospace;">Headache
18
513     3.5%
style="font-family: Courier New,Courier,monospace;">Nausea
24
513     4.7%
style="font-family: Courier New,Courier,monospace;">Dizziness          14
513     2.7%
style="font-family: Courier New,Courier,monospace;">.
etc.
It appears from your solution that I would need to create a separate
one-row table for each row
Regards,
Peter
ms
Yes, I tried that, it worked but it was a bit shaky. I did not save the script but the principle was something like this:
I used script that excluded all rows then a for loop where each iteration unexcludes the current row, run the nonlinear script (incl. saving the parameter value), and finally re-excludes the current row. However, sometimes I got erroneous results probably because the row exclusion/unexclusion completion was running ahead of completion the numerical nonlinear fitting. One could try to find the sweet spot using Wait()-commands or use some other way to force completion.
Another possibility would be to run the non-linear with a by-argument using column with unique ID for each row. and then loop through the different nonlinear objects to finish and get estimates:
Something like
pmroz
I figured out a way to do it that might be faster than using the
nonlinear function.  Takes about 12-18 tries in the loop
before finding an acceptable value.  Adjust
the epsilon parameter to get higher or lower precision.
 Takes less than a second on a table of 2400 values!
This was written in JMP 9 btw.
style="font-size: 10pt; font-family: "Courier New"; color: green;">/*
style="font-size: 10pt; font-family: "Courier New"; color: green;">Binomial
style="font-size: 10pt; font-family: "Courier New"; color: green;">Search
for upper and lower
style="font-size: 10pt; font-family: "Courier New"; color: green;">.05
and .95
style="font-size: 10pt; font-family: "Courier New"; color: green;">Uses
a table with columns called:
style="font-size: 10pt; font-family: "Courier New"; color: green;">Case
Count
number of cases for this
Preferred Term
style="font-size: 10pt; font-family: "Courier New"; color: green;">Total
Cases
total number of cases
style="font-size: 10pt; font-family: "Courier New"; color: green;">Add
two columns:
style="font-size: 10pt; font-family: "Courier New"; color: green;">Lower
CI Limit
style="font-size: 10pt; font-family: "Courier New"; color: green;">Upper
CI Limit
style="font-size: 10pt; font-family: "Courier New"; color: green;">*/
style="font-size: 10pt; font-family: "Courier New"; color: black;">
style="font-size: 10pt; font-family: "Courier New"; color: black;">dt
style="font-size: 10pt; font-family: "Courier New"; color: navy;">=
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">current
data table
style="font-size: 10pt; font-family: "Courier New"; color: black;">()
style="font-size: 10pt; font-family: "Courier New"; color: navy;">;
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><<
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">new
column
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Lower
CI
Limit"
style="font-size: 10pt; font-family: "Courier New"; color: navy;">,
numeric
Continuous
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Format
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Percent"
style="font-size: 10pt; font-family: "Courier New"; color: teal;">10
style="font-size: 10pt; font-family: "Courier New"; color: teal;">2
style="">
formula(
style="">
max_iterations
style="font-size: 10pt; font-family: "Courier New"; color: teal;">100
style="">
epsilon
style="">
style="font-size: 10pt; font-family: "Courier New"; color: teal;">.0001
style="">
lower_limit
style="font-size: 10pt; font-family: "Courier New"; color: teal;">.0000000001
style="">
upper_limit
style="font-size: 10pt; font-family: "Courier New"; color: teal;">.9999999999
style="">
target
style="font-size: 10pt; font-family: "Courier New"; color: teal;">.95
style="">
style="font-size: 10pt; font-family: "Courier New"; color: green;">//
Upper confidence interval
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">for
(i
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><=
max_iterations
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;">++,
style="">
test_b1
(lower_limit
upper_limit)
style="font-size: 10pt; font-family: "Courier New"; color: navy;">/
style="">
bd
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">binomial
distribution
style="font-size: 10pt; font-family: "Courier New"; color: black;">test_b1
style="font-size: 10pt; font-family: "Courier New"; color: navy;">:
style="font-size: 10pt; font-family: "Courier New"; color: black;">Total
Cases
style="font-size: 10pt; font-family: "Courier New"; color: black;">Case
Count)
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">if
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">abs
style="font-size: 10pt; font-family: "Courier New"; color: black;">bd
style="font-size: 10pt; font-family: "Courier New"; color: navy;">-
target)
epsilon)
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">break
style="">
style="">
(bd
target
style="">
then
style="">
upper_limit
test_b1
style="">
else
style="">
style="">
lower_limit
test_b1
style="">
style="">
style="">
test_b1
style="">
style="">
formula
style="font-size: 10pt; font-family: "Courier New"; color: black;">)
style="">
end new column
column
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Upper
CI
Limit"
numeric
Continuous
style="">
formula(
style="">
max_iterations
style="">
epsilon
style="">
style="">
lower_limit
style="">
upper_limit
style="">
target
style="font-size: 10pt; font-family: "Courier New"; color: teal;">.05
style="">
style="">
(i
i
max_iterations
i
style="">
test_b0
(lower_limit
upper_limit)
style="">
bd
distribution
style="font-size: 10pt; font-family: "Courier New"; color: black;">test_b0
Cases
Count)
style="">
target)
epsilon)
style="">
style="">
style="">
(bd
target
style="">
then
style="">
upper_limit
test_b0
style="">
else
style="">
style="">
lower_limit
test_b0
style="">
style="">
style="">
test_b0
style="">
style="">
formula
style="">
end new column
Thanks again for everyone's suggestions and help!
mpb
mpb
The Chadd's formula and it's lower bound counterpart should give the same upper and lower bounds as the method in the nist manual. I'll look up the other bound if you are interested. That would require no coding at all except to create the column forumulas.
It may be worth mentioning that the "exact" calculation is not necessarily considered "best" in the sense that the resulting interval may be unnecessarily wide. Here are a couple of papers in PDF format that are readily available and which you may find interesting.
http://projecteuclid.org/DPubS/Repository/1.0/Disseminate?view=body&id=pdf_1&handle=euclid.ss/1009213286
http://www.stat.iastate.edu/preprint/articles/2002-05.pdf
+1 on that. I'm an Adjusted Wald fan, personally.
