3 variable bar chart in JMP - one of variables is colour
I am trying to create a bar chart where the Y axis represents a count of unique species, the X axis represents a country and I want a third variable, sum of all animals in that country, to be represented as the colour fill of the bar. Is there a way to do this in JMP? Any help would be appreciated. thanks in advance.
pmroz
Re: 3 variable bar chart in JMP - one of variables is colour
You can do this with Graph Builder:
o In this example you have two columns: Country and Unique Species
o Start up Graph Builder and drag Country to the X axis
o Drag Unique species to the X axis
o Right click on a point and select Points > Change To > Bar
o Drag Unique Species to the upper right corner, Overlay
o Right click on a bar and select Bar > Bar Style > Stacked
Good luck!
Message was edited by: PMroz
