EOwl
Conditionally include box elements in a New Window();
I'm creating a custom column select GUI using New Window(), and the list of columns that need to be selected depend on the option selected in a previous window. How do I conditionally set which Box elements exist in the window? (in the figure, only orange exists if single was selected, only green if double).
I've tried something with Match() (commented out in the script) but no luck.
Clear Globals();
// Config.
window_Radio = New Window( "Wafermap viewer config.",
	<<modal,
	<<Size Window( 350, 200 ),
	Border Box( Left( 3 ), top( 10 ),
	// Select Level
		vb = V List Box(
			pb = Panel Box( "Select data configuration",
				Lineup Box( N Col( 2 ), spacing( 10 ),
					rb1 = Radio Box( {"Single"} ),
					rb2 = Radio Box( {"Double"} )
				<<Set Stretch( "Fill", "Off" )
			Spacer Box( size( 0, 10 ) ),
			H List Box(
				okbtn = Button Box( "OK", option = rb1 << Get();)
				, exitbtn = Button Box( "Cancel", /*window_Radio << CloseWindow*/)
	rb1 << group( rb2 );
//If cancelled stop script
if (window_Radio["Button"] != 1, stop());
colbox_width = 130;
window_colselect = New Window("Select identifying columns",
	<< Type( "Dialog" ),
		V List Box(
			H List Box(
				V List Box(
					Panel Box( "Select Column(s)",
						colListData = Col List Box( dt, All
							, width( colbox_width ), nLines( Min( N Col( dt ), 10 ) )
				V List Box(
					Panel Box( "Column Role(s)",
						Lineup Box( N Col( 2 ), Spacing( 3 ),
/*							//####Conditional JSL Attempt####
							Match(option,
							1, Expr(
							//Single col select
							btnLotID = Button Box( "Lot", colListLotID << Append( colListData << GetSelected ) ),
							colListLotID = Col List Box( width( colbox_width ), minitems( 1 ), nLines( 1 ), character ),
							2, Expr(
							//Select col 1
							btnLotRoot = Button Box( "Lot Root", colListLotRoot << Append( colListData << GetSelected ) ),
							colListLotRoot = Col List Box( width( colbox_width ), minitems( 1 ), nLines( 1 ), character ),
							//Select col 2
							btnBatch = Button Box( "Batch", colListBatch << Append( colListData << GetSelected ) ),
							colListBatch = Col List Box( width( colbox_width ), minitems( 1 ), nLines( 1 )),
							//####### option = 1 #########
							//Single col select
							//####### option = 2 #########
							//Select col 1
							//Select col 2
				Panel Box( "Action",
					Lineup Box( N Col( 1 ),
						Button Box( "OK", /*OK Actions*/),
						Button Box( "Cancel", /*Cancel Actions*/),
						Button Box( "Reset", /*Reset Actions*/),
						Button Box( "Remove", /*Remove Actions*/),
						Button Box( "Recall", /*Recall Actions*/)
Sidebar, I can't get the panel box with the radio buttons to stretch to fill the window, how can I do that without manually matching the window size?
Re: Conditionally include box elements in a New Window();
If Box() is one quite easy option to use
New Window("Example",
	H List Box(
		englishBox = If Box(1, Text Box("Good day")),
		frenchBox = If Box(0, Text Box("Bon Jour"))
Wait(5);
englishBox << Set(0);
frenchBox << Set(1);
	H List Box(
Wait(5);
For the panel box stretching I think you could for example add "blank" Spacer box as the first display box
window_Radio = New Window("Wafermap viewer config.",
	<<Type("Modal Dialog"),
	<<Size Window(350, 200),
	Spacer Box(<< Set Stretch("Window", "Off")),
	Border Box(Left(3), top(10),
		vb = V List Box(
			pb = Panel Box("Select data configuration",
				Lineup Box(N Col(2), spacing(10),
					rb1 = Radio Box({"Single"}),
					rb2 = Radio Box({"Double"})
				<<Set Stretch("Fill", "Off")
			Spacer Box(size(0, 10)),
			H Center Box(Lineup Box(N Col(2),
				okbtn = Button Box("OK", option = rb1 << Get()),
				exitbtn = Button Box("Cancel", /*window_Radio << CloseWindow*/)
	rb1 << group(rb2)
An alternative to IfBox is to use the Visibility property that each display box has:
	H List Box(
		englishBox = Text Box("Good day"),
		frenchBox = Text Box("Bon Jour", <<Visibility("Collapse"));
Wait(5);
englishBox << Visibility("Collapse");
frenchBox << Visibility("Visible");
