JMPUser9
Conditional Formatting
I have data that contains different lots and reps and then time stamps.
I want all of the data from the same lot/rep to be divided by the final time stamp.
How would I do this in the formula section of a column?
Re: Conditional Formatting
Col Max() with byvars (lot and maybe rep, depending on your data) should work.
dt << New Column("f", numeric, continuous, Formula(
	:height / Col Maximum(:height, :sex)
JMPUser9
Thank you, worked perfectly.
