AdamChoen
Condition error
hello
I'm trying to do a delta check between neighboring cells value on the same column.
For( i = 1, i <= N Row( dtB ), i++,
    If(
        i == 1,
            If( Abs( :Delta[i] - :Delta[i + 1] ) <= 0.1,
                dtB:Check[i] = "Pass",
                dtB:Check[i] = "Fail"
        i == N Row( dtB ),
            If( Abs( :Delta[i] - :Delta[i - 1] ) <= 0.1,
        If( Abs( :Delta[i] - :Delta[i + 1] ) <= 0.1 | Abs( :Delta[i] - :Delta[i - 1] ) <= 0.1,
i get this result
but line 5 should not fail
when I check it thru the log it seems like a bug or I'm missing something
appreciate your inputs
i
5
:Delta[i]
0.3
:Delta[i+1]
0.4
abs(:Delta[i] - :Delta[i+1])
0.1
abs(:Delta[i] - :Delta[i+1]) <= 0.1
0
Thanks, Adam
11 REPLIES 11
AdamChoen
Re: Condition error
it's not an issue for me, i like to do that
Thanks, Adam
Craige_Hales
Re: Condition error
0.1 is a repeating fraction in binary. In IEEE floating point, it is rounded at 52 or 53 bits, so it must be either a bit too big or a bit too small.
Good binary fractions are sums of  1/2, 1/4, 1/8, 1/16, 1/32, ... 1/2^53 which are the individual bits of the fraction.
Sometimes the "bit too big" or "bit too small" works out the way you want, and sometimes not.
The second example shows an epsilon chosen for numbers near 1, which have about 14 places after the decimal (thus 1e-12).
If( .3 - .2 == .1, // "no"
    "yes"
, // else
    "no"
If( Abs( (.3 - .2) - .1 ) < 1e-12, // "yes"
    "yes"
, // else
    "no"
Old post
Craige
