RonSwanson
Concatenate table values into a string variable
I have a table of characters and want to produce a string variable of the concatenated values of each column to use as the argument of a function.
Let's say this is my table of data:
Column1 Column2
Item1       Value1
Item2       Value2
Item3       Value3
Item4       Value4
Item5       Value5
The table will have 2 columns but any number of rows. The output I'm looking for is this:
strColumn1 = 'Item1','Item2','Item3','Item4','Item5'
strColumn2 = 'Value1','Value2','Value3','Value4','Value5'
Any help much appreciated!
uday_guntupalli
Level VIII
Re: Concatenate table values into a string variable
@RonSwanson,
         Maybe something like this
dt = Current Data Table();
Col1Vals = dt:Column 1 << get Values;
Col2Vals = dt:Column 2 << get Values;
// If you are specific about how the output looks, you can try the following, else
// the above lines should give you what you want
Str1 = "";
Str2 = "";
for(i = 1, i <= N Items(Col1Vals), i++,
		If(i == 1,
				Str1 = Str1 || Col1Vals[i];
				Str2 = Str2 || Col2Vals[i];
				//else
				Str1 = Str1 || "," || Col1Vals[i];
				Str2 = Str2 ||  "," ||Col2Vals[i];
Best
Uday
RonSwanson
The Col1Vals command worked, however, got the following error when using the Col2Vals command:
Scoped data table access requires a data table column or variable in access or evaluation of 'dt:Column 2' , dt:Column 2
In the following script, error marked by /*###*/
pmroz
Looks like you're trying to create an SQL IN list.  Here's another approach:
dt = New Table( "Untitled 81", Add Rows( 2 ),
	New Column( "Column 1", Character, "Nominal", Set Values( {"Item1", "Item2"} ) ),
	New Column( "Column 2", Character, "Nominal", Set Values( {"Value1", "Value2"} ) )
col1_list = column(dt, "Column 1") << get values;
col2_list = column(dt, "Column 2") << get values;
strcolumn1 = "('" || concat items(col1_list, "','") || "')";
strcolumn2 = "('" || concat items(col2_list, "','") || "')";
If any of the columns are numeric then the list returned from get values will be a matrix, and you will need to loop over the matrix to convert all elements to strings.
uday_guntupalli
Level VIII
@RonSwanson,
       Just make sure the column name is spelled correctly. Preferrably delete the space in the name of the column.
Best
Uday
