Christian
Concatenate Tables and close the input files
I am looking for a way to close the tables that are open and have served for input
For( f2 = 1, f2 < N Items( Tables ), f2++,
        ConcTable = Tables[f2] <<  /*###*/Concatenate(
            Tables[f2 + 1],
            Output Table Name( "Both" )
        Close( filelist[f2], No Save );
The answer in the log is:
Send Expects Scriptable Object in access or evaluation of 'Send' , Tables[f2] <<  /*###*/Concatenate( Tables[f2 + 1], Output Table Name( "Both" ) ) /*###*/
Re: Concatenate Tables and close the input files
here is a simple method to concatenate the tables, and close those not needed
Final_Table="Data_" || char(ntable);
// Concatenate the tables and delete them.  Add all of the tables to the first table
dt-data table(1);
For( i = 2, i <= N Table(), i++,
	dt << concatenate(data table(i), append to first table(1));
	close(data table(i), nosave);
// Rename the table to the desired name
dt << set name(Final_Table);
7 REPLIES 7
Here is a piece of code that will work, and follows the logic of what you have specified.  However, I don't understand why you would want to do this.......so maybe the result will not be what you are imagining.  If not reply with what the end result is supposed to be.
// Create sample tables
dt = Open( "$SAMPLE_DATA\big class.jmp" );
dt << subset( selected rows( 0 ), selected columns( 0 ), by( :age ) );
Close( dt, nosave );
// Create your Tables list
Tables = {};
For( i = 1, i <= N Table(), i++,
	Insert Into( Tables, Data Table( i ) << get name )
// Run the concatinations
	ConcTable = Data Table( Tables[f2] ) << Concatenate( Data Table( Tables[f2 + 1] ), Output Table Name( "Both" ) );
	Close( Data Table( Tables[f2] ), No Save );
Christian
Jim, thanks for the answer. Let me expand a little further. Goal is to concatenate a list of data tables and to delete double rows. Any data tables that have contributed to the final concatenated table to be closed. The number of input data tables is variable. The selection of the datatbales to be concatenated is following the rule that the beginning strings are equal and the final name of the concatenated data table is the same string.
Here now the code for concatenation and double row deletion plus saving the final table.
If(N Items(filelist)>0,
for    (nu_t = 1, nu_t <= num_tables, nu_t++,
FinalTable  = Munger(filelist[1],6,4);
Final_Table = "Data_"||FinalTable||".jmp";
//Show(FinalTable);
for    (f2 = 1, f2 < nitems(Tables), f2++,
    ConcTable = Tables[f2] << Concatenate(Tables[f2+1], Output Table Name( "Both" ) );
    Close( Tables[f2] , No Save );
    // Delete Doube Rows
    ConcTable = Current Data Table();
    col_min = Parse( "Col Min( Row(), :Name(\!"" || Concat Items( ConcTable << get column names( string ), "\!"), :Name(\!"" ) || "\!"))" );
    duplicates = [];
    For Each Row( If( col_min != Row(), duplicates |/= Row() ) );
    ConcTable << delete rows( duplicates );
ConcTable << Save(Path_datatable_out||Final_Table);
//For(cc=1,cc <= nitems(Tables),cc++, Close(Tables[cc], No Save));
); // If Condition
I am looking forward for your reply.
Christian
Can you please supply a sample of you data tables, and an illustration of what would be considered duplicate rows?
Christian
Jim,
If you look in the two attched table, they have the same number of columns and column names. The only thing that differentiate both is the number of rows. Column #1 is the time stamp and based on this duplicates will be removed.
The method as scripted works. I am looking for an efficent way of saving the final table and close the tables that have been the input for the final.
Best regards,
Christian
dt-data table(1);
rc_hertzy
Nice solution. First, a typo (equal sign not minus sign):  fourth line should be
dt=data table(1);
Now, how can I keep one column for the source? If I merely add
Create source column
in the Concatenate statement, I get successive source columns, and none is what I want - listing all source files.
Related: when I manually concatenated files and copied the Source script from the output file to a script window, it would not run, giving error of not finding the listed filenames. Here is the script ( File1.jmp is the selected open file):
dt = Current Data Table();
dt << Concatenate(
Data Table( "File2.jmp" ),
Data Table( "File3.jmp" ),
Output Table( "Combinedtest.jmp"),
 Thanks. -Rick
rc_hertzy
dt=data table(1);
dt << Concatenate(
 Thanks. -Rick
I found my error in the last part. I had renamed one data file so of course the script could not find it.
Still I would like a way to modify your solution to add a source column so I do not need to explicitly list all the open files. Thanks.
