Jackie_
Similar keys
Value column.
Re: Similar keys
I would do this by utilizing SQL. This example should give an idea what you can do, you will have to do some cleanup on the values though
dt_main = Open("$DOWNLOADS/maintable(1).jmp");
dt_ref = Open("$DOWNLOADS/referencetable(1).jmp");
dt_concat = Query(
	Table(dt_main, "t1"),
	"\[SELECT type, "X Coord", "Y Coord", "Wafer ID", GROUP_CONCAT(Value, ', ') as Value
	FROM t1
    group by type, "X Coord", "Y Coord", "Wafer ID"
dt_split = dt_concat << Split(
	Split By(:Type),
	Split(:Value),
	Group(:X Coord, :Y Coord, :Wafer ID)
dt_ref << Update(
	With(dt_split),
	Match Columns(:X Coord = :X Coord, :Y Coord = :Y Coord, :Wafer ID = :Wafer ID),
	Add Columns from Update Table(:A, :B),
	Replace Columns in Main Table(None)
Add Listagg/Concatenate/GROUP_CONCAT to Summary platform for a wishlist which should make this very easy
Edit:
Casting seems to be fairly simple way to get rid of the decimals
View more...
dt_concat = Query(
	"\[SELECT type, "X Coord", "Y Coord", "Wafer ID", GROUP_CONCAT(CAST(Value as int), ', ') as Value
	FROM t1
	Split By(:Type),
	Split(:Value),
Close(dt_concat, no save);
dt_ref << Update(
	With(dt_split),
Close(dt_split, no save);
Re: Similar keys
dt_concat = Query(
	FROM t1
	Split By(:Type),
	Split(:Value),
dt_ref << Update(
	With(dt_split),
Edit:
View more...
dt_concat = Query(
	FROM t1
	Split By(:Type),
	Split(:Value),
dt_ref << Update(
	With(dt_split),
Jackie_
Re: Concat row values
Thanks a lot Jarmo!
