nv11
Comparing two rows with the same time stamp and picking the higher value from a different column
Hi, I have a dataset where by I have a single column with minute by minute data (time stamped) and in many cases the same minute is duplicated. For those instances, there is another column with different values. How do I find duplicated timestamp rows and pick the max. value between them e.g.
Initial Table
Time      Flow
12:00     345
12:01     123
12:01      456
12:02      223
12:02      112
12:03      234
Final Table
Time      Flow
12:00     345
12:01      456
12:02      223
12:03      234
Thank you. FYI - using JMP Pro 17 and I am an amateur (2hrs of experience).
Thierry_S
Re: Comparing two rows with the same time stamp and picking the higher value from a different column
I suggest using the Table Summary tool with the Flow column set to MAX and the Time column set to Group.
Best,
TS
Thierry R. Sornasse
Thierry_S
Best,
TS
Thierry R. Sornasse
nv11
Thank you for the feedback - unfortunately I might be too early in my JMP journey to understand how to apply this solution
Go to the Tables pull down menu and select Summary
