HenningWeiss
Comma to dot in a table column without changing preferences
Hi JMP community,
I would like to change comma to dot in a table column.
Boundary conditions:
- I am importing data with a script from my colleague - hence I cant change the script
- I get a table that contains the data as character in a column, I want to plot it
- the data contain a comma as decimal separator
- I dont want to change the overall settings of JMP, I only want to yield a new column that contains the data now with comma replaced by dot
-  I dont want to create a new script handling this in jsl (I have that), I want this to be possible with a few clicks from f.ex. the column properties. Its a standard action after all.
Any ideas or solutions out there!?
Thanks a lot! Looking forward to an approach.
Best, Henning
ian_jmp
Level X
Re: Comma to dot in a table column without changing preferences
If your character column were called "In", here's one way using a formula:
ian_jmp
Level X
HenningWeiss
Hello Ian,
thanks a lot for that quick reply and a good way to solve the problem.
I accepted as answer.
Best, Henning
