jsolo01
Combining rows with serial data
Hi - there are a few posts on this but they dont address this specific issue
i need to get from example 1 to example 2.  combine rows by ID # into one row with data aligned sequentially.  Thanks
example 1
id    visit#.   PGA
1      1          5
1      2          3
2      3        12
2      5         7
2      6         4
example 2
id.   visit#    PGA.   visit#.   PGA.    visit#.  PGA#
1.      1         5          2           3
2.       3        12        5           7           6         4
Re: Combining rows with serial data
One option is to create new grouping column with something like
Col Cumulative Sum(1, :id)
after this you can split the table
and end up with
then you can move the columns around
and end up with
jsolo01
that works!  Thanks
fja
fja
@jsolo01 wrote:
that works!  Thanks
Lovely! Could you mark @jthi 's answer as a solution then? ... and generously spare it a kudo/like ...  just to keep people motivated.
