Silver22
Columns containing numbers and numbers with a letter
Dear JMP community,
I have a problem with opening a data table and I use the JMP 17 version.
I have a data table (xlsx file) with many columns containing numbers and strings. Some of the columns contain both numbers and strings. My problem is, when JMP opens a column of a data table and in the first row there is a number and in the remaining rows there are numbers with an initial letter (e.g. R4562), JMP sets the data type to Numeric and all remaining rows are deleted because they contain a letter. This is not nice. Furthermore, the content of the column must not be changed.
Is there a workaround where I can set the data type of the column before JMP opens the xlsx file?
Thank you very much for your help.
mmarchandFSLR
Re: Columns containing numbers and numbers with a letter
Try using the Excel Wizard to open it.
Silver22
Thank you for your suggestion, but I don't think I can use the Excel Wizard because I don't open Excel manually, I use the "open" command and this is part of a JMP script.
Kind regards,
B
If you can edit the script, you use the wizard first interactively and JMP will then create a script for you which you can use.
I think JMP17 messes up before the data is even loaded (JMP18 seems to be able to open the file correctly).
Data preview looks very weird when you tell JMP that there are no headers (columns 1 and 2 have missing values)
Silver22
Hello Jarmo,
Thanks for the help. I didn't realized that no column headers are so important. I do of course have column header (Sample, Vendor and Date). But I'm struggeling with the 2 data types in a column. If there is a number in the first row, JMP set the data type to numeric and deletes the rest of the rows. Does that mean I have to wait for JMP 18 and can't do anything about it?
Kind regards,
Britta
