Onjai
Column property options in JMP 15
I just upgraded to JMP 15 and noticed the "Row Order Levels" column property is not an available option.  Is this property available?
Thank you.
Re: Column property options in JMP 15
Row Order Levels is now combined with Value Order.  It is set with
dt:col << set property("Value Order", {Row Order Levels(1)});
Onjai
Perfect.  That works.
Thank you.
Cheers.
