Onjai
Column formula to round timestamp to nearest minute
Looking for a column formula to round timestamp to nearest minute.
27/06/2017 12:21:13 PM  need to round to 27/06/2017 12:21:00 PM.
Any suggestions?
Cheers.
julian
Re: Column formula to round timestamp to nearest minute
Hi @Onjai,
I'm sure there are other ways to approach this, but I've had luck with the following when I've needed to do that (this requires that you have a numeric :DateTime column):
Round(:DateTime / 60) * 60
(Edited: replaced with the simpler formula pointed out by Jerry)
Hope this helps!
@julian
Onjai
I am using the latest version of JMP.  The transform worked as well.
Thank you!
julian
Hi @Onjai,
Hope this helps!
@julian
Onjai
Julian,
This worked just fine.
Thank you.
jerry_cooper
Staff (Retired)
Hi Onjai,
If you're using version 14, you can right-click the heading of your Timestamp column, select New Formula Column->Transform->Round. You'll then get a dialog box to set the desired parameters (because you're wanting to round to the nearest minute, you'll just need to select "Nearest" from the dropdown and click OK). This is the resulting formula:
Round(:Timestamp / 60) * 60
Onjai
Thank you!
:Time Stamp - Modulo( :Time Stamp, 60 );
