ashwint27
Column Switcher selection to dynamically label column in data table
I am interested in utilizing the Column Switcher in Graph Builder to where I select a column within the Column Switcher, and it dynamically sets the corresponding data table's column as a "label" column.  It should also "unlabel" any previously labeled data table columns no longer selected within the Column Switcher.  Is there a way this can be accomplished?  I am using JMP version 19.
Re: Column Switcher selection to dynamically label column in data table
Using a Make Column Switch Handler, you should be able to add the JSL required to make your required changes when the Column Switcher is used.  See the Scripting Index for a description of and example of the Make Column Switch Handler.
