ashwint27
Column Switcher selection to dynamically label column in data table
I am interested in utilizing the Column Switcher in Graph Builder to where I select a column within the Column Switcher, and it dynamically sets the corresponding data table's column as a "label" column.  It should also "unlabel" any previously labeled data table columns no longer selected within the Column Switcher.  Is there a way this can be accomplished?  I am using JMP version 19.
ashwint27
Re: Column Switcher selection to dynamically label column in data table
Thanks Jim.  I adapted the example script in the Scripting Index for "Make Column Switch Handler" and this code seems to work for what I was looking for:
dt = Open( "$SAMPLE_DATA/Process Measurements.jmp" );
gb = Graph Builder( Variables( Y( :Process 1 ) ), Elements( Histogram( Y, Legend( 3 ) ) ) );
dt << Clear Column Selection();
columnSwitcher = gb << Column Switcher(
	:Process 1,
	{:Process 1, :Process 2, :Process 3, :Process 4, :Process 5, :Process 6, :Process 7}
dt << Set Label Columns();
dt << Set Label Columns( :Process 1 );
pre = Function( {currentColumn, nextColumn, switcher},
	Print(
		"Before switch: " || (currentColumn << get name) || " >> " || (nextColumn << get name) ||
		" [Column Switcher] current: " || (columnSwitcher << Get Current)
	currentColumn << Label( 1 );
post = Function( {previousColumn, currentColumn, switcher},
	Print(
		"After switch: " || (previousColumn << get name) || " >> " || (currentColumn << get name) ||
	previousColumn << Label( 0 );
handler = columnSwitcher << Make Column Switch Handler( pre, post );
Using a Make Column Switch Handler, you should be able to add the JSL required to make your required changes when the Column Switcher is used.  See the Scripting Index for a description of and example of the Make Column Switch Handler.
ashwint27
	:Process 1,
	Print(
	Print(
