datanaut
Column Switcher Button Removed from Plot Window Toolbar in JMP 16 for Mac
Recently switched from JMP15 for Mac to JMP16 for Mac.
I was surprised to see the column switcher button removed as an option in an analysis/plot window.  It used to reside up top next to the local data filter button (see black circle).  The option to customize it back is also missing and has been replaced by a 'properties' button.  This may also prove useful but I'm new to it.
To get the column switcher I now have to go to the red triangle->redo to access a column switcher.  So it's still available but much less convenient.  This used to be one advantage to Mac vs Windows.  Can I reconfigure this?
Maybe I can configure a Mac shortcut for this instead?
0 REPLIES 0
