Column Selection issue
I am creating a visualization, storing all open file names in a listbox. I then want to select a specific file and display all numeric columns from that file into a colListBox. Oddly, this seems to work only for a file I created myself and not for two additional files from the sample directory. I tried setting the table of choice to the 'current datatable' but I am unable to figure out how to switch columns when I switch table.
Currently it loads the columns for my defects.jmp table and not the others.
ns = newNameSpace();
// Get some Data
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );		// JMP Library.
dt1 = Open( "$SAMPLE_DATA/Football.jmp" );		// JMP Library.
dt1 = Open( "defects.jmp" );					// Troy Local File.
// Get a list of open files
openDTs = {};
for(i=1, i<= nTable(), i++,
	insertInto(openDTs, dataTable(i))
// Create File and Column Selector
selectionWindow = newWindow("Col Selection Test",
	ns:tableBox = listBox("", << setwidth(200), << setNLines(5), maxSelected(1),
		selectedTable = (ns:tableBox << getSelected)[1];
		currentDatatable(dataTable(selectedTable));
		colList = dataTable(selectedTable) << getColumnNames("Numeric");
		show(colList);
		ns:columnBox << setItems(colList);
	ns:tableBox << setItems(openDTs);
	ns:columnBox = colListBox({}, width(177), << setNLines(5), maxSelected(1));
	hListBox(ns:tableBox, ns:columnBox);
When I select 'defects' I get the following which is the desired result
However, subsequent selections of the other tables do not populate the columns
defects.jmp table
I've tried various options but nothing seems to work??? Weird.
Any suggestions?
Re: Column Selection issue
You will have to replace Col List Box as it will refer to specific data table
ns = New Namespace();
Open("$SAMPLE_DATA/Big Class.jmp");
Open("$SAMPLE_DATA/Football.jmp");
Open("$SAMPLE_DATA/Cars.jmp");
dts = Get Data Table List() << get name;
selectionWindow = New Window("Col Selection Test",
	H List Box(
		lb = List Box(
			dts,
			<< Set Width(200),
			<< Set NLines(5),
			maxSelected(1),
			sel_vals = lb << Get Selected;
			If(N Items(sel_vals) > 0,
				(clb_collector << Child) << Delete Box();
				clb_collector << Append(
					clb = Col List Box(Datatable(sel_vals[1]),
						<< Set Items(Data Table(sel_vals[1]) << Get Column Names("Numeric", "String")),
						<< Set Data Type("Numeric"),
						width(177),
						<<setNLines(5),
						maxSelected(1)
		clb_collector = V List Box(
			clb = Col List Box(Current Data Table(),
				<< Set Items(Current Data Table() << Get Column Names("Numeric", "String")),
				width(177),
				<<setNLines(5),
				maxSelected(1)
lb << Set Selected(Contains(dts, Current Data Table() << get name));
Write();
Awesome, thanks Jarmo.
Delete and re-append. Why didn't I think of that.
Also, I wasn't aware of function 'Get Data Table List()' which is very handy :)
Thanks for the quick reply.
	H List Box(
		lb = List Box(
			dts,
			<< Set Width(200),
			<< Set NLines(5),
			maxSelected(1),
						width(177),
						<<setNLines(5),
						maxSelected(1)
				width(177),
				<<setNLines(5),
				maxSelected(1)
Write();
