SpannerHead
Column Names With A Numeric Initial
I have a code that stumbles with column names having a numeric initial, whereby the code thinks the name represents a date.  I did a column rename to overcome the problem but it's ugly.  I also found that wrapping the object that represents the names in a Char(obj) statement didn't work either.  Any suggestions on how to better deal with this?
cnmes = dt << get column names( "string" );
For( j = 1, j <= N Items( cnmes ), j++,
        if (Starts With( cnmes[j], "1" ) == 1 | Starts With( cnmes[j], "2" ) == 1 | Starts With( cnmes[j], "3" ) == 1| Starts With( cnmes[j], "4" ) == 1 | Starts With( cnmes[j], "5" ) == 1 | Starts With( cnmes[j], "6" ) == 1 | Starts With( cnmes[j], "7" ) == 1 | Starts With( cnmes[j], "8" ) ==1 | Starts With( cnmes[j], "9" ) == 1 | Starts With( cnmes[j], "0") == 1 ,
        Column(cnmes[j]) << set name("_"||cnmes[j])
Slán
SpannerHead
Re: Column Names With A Numeric Initial
You are seeing those issues as Names have to start with either alphabetic character or with underscore Scripting Guide > JSL Building Blocks > JSL Syntax Rules > Names . Depending on what you are doing, you might want to rename them or not (see txnelson's options), for renaming you could for example utilize regex with something like this
dt = New Table("Untitled",
	Add Rows(0),
	Compress File When Saved(1),
	New Column("1col", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("13col", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("0col", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("Column 4",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([])
colnames = dt << Get Column Names("String");
For Each({colname}, colnames,
	newname = Regex(colname, "^\d+.+", "_\0");
	If(!IsMissing(newname),
		Column(dt, colname) << Set Name(newname);
You can use the Column() function to reference column names in your "cnmes" list of column names.  Or if you are hard coding the column names, using the following
// Report snapshot: Big Class - Graph Builder
Data Table( "Big Class" ) << Graph Builder(
	Variables( X( :"1height"n ), Y( :"1height"n ) ),
	Elements( Points( X, Y, Legend( 6 ) ), Smoother( X, Y, Legend( 7 ) ) )
names default to here(1);
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
// Change column name: height → 1height
try(Data Table( "Big Class" ):height << Set Name( "1height" ));
// Change column name: weight → 3weight
try(Data Table( "Big Class" ):weight << Set Name( "3weight" ));
Graph Builder(
	Variables( X( column(cnmes[5])), Y(  column(cnmes[4]) ) ),
	Add Rows(0),
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([])
