VT23
Column Formula to Determine Test Order for Repeated Samples
Attached is JMP file and want to replicate the Test Order column with column formula. Test Order column is based on SerialNo and TransactionBegDtm across multiple LotNo. Goal is to know if the SerialNo tested 1st vs 2nd based on TransactionBegDtm. I tried formula below, but was not able to get the correct matching sequence.
dt = Current Data Table();
dt << New Column( "Duplicate", Formula( Col Cumulative Sum(If(Row() == Col Min(Row(), :SerialNo, :TransactionBegDtm, :LotNo), 1, 2), :SerialNo, :TransactionBegDtm) );
Re: Column Formula to Determine Test Order for Repeated Samples
It is easiest of you sort your data first by transactionbegdtm to make sure the ordering is "correct", then you might be able to use something like
Col Cumulative Sum(1, :SerialNo, :LotNo))
Also if there can only be either 1 or 2 as test order, you can use something like
	If(:TransactionBegDtm == Col Min(:TransactionBegDtm, :SerialNo, :LotNo),
		1
	, 2
		1
	, 2
VT23
Thanks for the quick response, I was able to use the second method in your solution and that worked out.
