lisamaley
Colors in 3D Scatterplot Plot
I am helping someone with a scatterplot 3D again.   We found the coloring option in the menu.  This colors the points nicely, but when we connect the points, the lines are not colored to match the points.  Is there a way to get the lines to be the same color of the points?
I have a Mac Monterey 12.6 and running JMP Pro 16.
Thierry_S
Re: Colors in 3D Scatterplot Plot
It does not appear that there is an option in Scatter Plot 3D to color the connected lines based on a variable or even a constant.
If you search the Scripting Index for "Scatter Plot 3D", you will see all the modifiers for this object. None include Line Color.
Sorry I could not help further.
Best,
TS
Thierry R. Sornasse
lisamaley
Ok. thanks. I could not find anything either, but I was hoping I  overlooked something.
