DownloadSemiconductor Toolkit: Tools to create wafer maps, add wafer geometry to graphics, explore die defects & compare wafers.
Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Use JMP Clinical with CDISC-compliant data. Review studies, ID safety and efficacy signals & communicate findings with interactive graphics. Register to see how. Aug. 27, 2 pm US ET.
Thanks MS, but the syntax works only on column 1. Are there any ways to make it work for all the columns? My example has only 4 columns but in practice, I'm actually having 200+ so I'm trying to figure out if there are any ways to do that.
First add a Value Colors column property, then use the Color Cell by Value( 1 ) message to apply the colors. You can use a gradient as the color theme for the column property.
See Help > Scripting Index, then select Data Table object > Column Scripting protocol and finally select Color Cell by Value message.
Actually, I am not sure about the 'selected rows only' requirement. You might have to compute the associated color value and apply it to specific rows without the value color property.
The color gradient does not honor excluded rows, so the best method that I found(a bit of a kluge) is below. I colors all of the cells, and then comes back and changes to cell color for those colors you want to be changed back. But it does it by placing a cell color on top of the gradient color.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
dt:height << Set Property( "Color Gradient", {"Blue to Gray to Red"} );
dt:height << Color Cell by Value;
colorlist = As List( dt << get rows where( :sex == "F" ) );
dt:height << color cells( "White", colorlist );
