Created:
Sep 14, 2022 07:58 AM
| Last Modified: Jun 10, 2023 4:54 PM(2004 views)
Is there a way to collapse Table Variables/Scripts from Data Box / change height of Columns list to hide it? Or is there any other way of getting column listing from data table with same functionalities?
What I have:
What I would like to have:
dt = Open("$SAMPLE_DATA/Big Class.jmp", invisible);
New Window("Big Class",
H List Box(
lb = List Box(dt << Get Column Names("String"),
dt << Select Columns(lb << Get Selected);
H List Box(dg = dt << New Data Box())
dg << close data grid(1);
I could try hiding it with Padding but that sounds like more trouble than I really want
H List Box(
Border Box(Sides(15),
H List Box(dg = dt << New Data Box(), Text Box(" asdasd"))
dg << Set Auto Stretching(0,0);
dg << Padding(Left(0), Top(-210), Right(0), Bottom(0));
Have you tried a Col List Box with the grouped property turned on?
Data Table( "Big Class" ) << Group Columns( "height etc.", {:height, :weight} );
New Window( "Col List Box Example 1", Col List Box( all, width( 250 ), grouped, maxSelected( 1 ) ) );
