seb38360
Col Mean behaviour with hide/exclude
Hello, I observe that when I use ColMean function in one column that the value in the column is not updated when I hide/exclude some rows.
I think this is not a normal behaviour - there is no automatic recalculation.
May be we can avoid this with script but I would prefer to avoid.
If someone has a solution, thank you in advance
Regards
Sébastien
uday_guntupalli
Level VIII
Re: Col Mean behaviour with hide/exclude
@seb38360,
 Try this.
dt << New Column("Test",Numeric,Continuous,Formula(Col Mean( :height)));
dt << Select Randomly(0.1) << Exclude;
dt << New Column("Test",Numeric,Continuous,Formula(Col Mean(If(Excluded(), ., :height))));
Best
Uday
