ShriHanuman
Clustering Analysis?
Can I use clustering analysis with continuous variable target? I am using SAS jmp. I tried using continuous variable for hierarchical clustering but the answer returned an error. What am I missing?
Attached is the data set.
Salesprice is my continuous target variable
Re: Clustering Analysis?
  1. Select Analyze > Clustering > Hierarchical Cluster.
  2. Select SalesPrice.
  3. Click Y, Columns.
  4. Click OK.
I did not encounter any errors up to this point.
This unsupervised method found eight clusters, each of which with two sub-clusters, as indicated in the dendrogram or the constellation plot.
  4. Click OK.
dale_lehman
I don't understand this solution.  What is the sense of clustering on a single target variable?  I thought the whole idea of clustering was to find clusters of observations that are "similar" and then perhaps might related to a target variable.  How is clustering on a single target variable any different from looking at a distribution of that variable and seeing if there are any groups?  And, from your solution, what are the X,Y coordinates of the constellation (when there is a single variable being clustered)?
