waltp
Chinese cities shapefile
I'm looking for a shapefile for Chinese cities so I can plot Chinese population size by cities. Does anyone know where I can get a shapefile? Also, how to incorporate it into JMP? And where are shapefiles stored in JMP?
Thanks,
Walt Paczkowski
Re: Chinese cities shapefile
Hi Walt,
Mainland China provinces shapefiles are already present in your JMP installation, however in general a good resource where you can find ESRI Shapefiles for different countries in the world, is the following website:
http://www.diva-gis.org/gdata
If you want to know what you can do with them, and how to incorporate them in JMP, Jeff Perkinson years ago wrote a paper for JMP V9:
Create Compelling Visualizations with Geographic Data and JMP® 9
that is still valid and useful: page 9 is a sort of tutorial (just change V9 path into V14, of course...)
Bye, Massimo
waltp
Good morning Massimo,
Thanks for the response.  I'll look at Jeff's post to learn more.
Walt
