Not completely sure this is appropriate for the problem, but given that you are looking at a proportion and count data, using Fit Model>Generalized Linear Model might help. Set the Observed Injures and the Staff Level in the Y (as Continuous) then Dept as a Model effect. Choose Binomial Distribution and leave the Link Function as Logit.
The result is a series of ChiSquare tests, but not necessarily the same as the Contingency Analysis in Fit Y by X. Here we are testing if there a difference in the proportion of injuries to staff level per department. Whole model fit ChiSquare, Effect ChiSquare and Parameter Estimates (levels) ChiSquare's are calculated.
Goodness of Fit is not calculated. The Whole Model ChiSquared is the same as the Likelihood Ratio results in Fit Y by X. No Mosaic Plot either for communicating results graphically either.
Something to think about given the structure of your data.
Chris Kirchberg, M.S.
2Data Scientist, Life Sciences - Global Technical Enablement
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail:
[email protected]www.jmp.com
