ARETI052
Check box won't show up in an input prompt input
// New dialog for script selection
scripts = {"Box Plot", "Box Plot_sublot_trend", "Box Plot_duration_trend", "Box Plot_FT1vsFT2", "Tabulation", "CDF&PDF11"};
scriptSelections = J(1, N Items(scripts), 0);
// Initialize the checkboxes array
cb = {};
nw2 = New Window("Script Selection", <<modal,
    <<onClose(
        For(i = 1, i <= N Items(scripts), i++,
            scriptSelections[i] = cb[i] << Get;
    VListBox(
        Text Box("Select the scripts to run:"),
        Panel Box("Scripts",
            V List Box(
                    cb[i] = Check Box(scripts[i], 0);
        HListBox(
            Button Box("OK", nw2 << Close(1)),
            Spacer Box(size(6, 0)),
            Button Box("Cancel", nw2 << Close(0))
if (nw2["Button"] == -1, throw());
selectedScripts = {};
    If(scriptSelections[i] == 1,
        Insert Into(selectedScripts, scripts[i]);
New Window("My report",
    VListBox(
        MyGraph(::yColName, ::xColName, ::xGroupName)
// Include selected scripts
For(i = 1, i <= N Items(selectedScripts), i++,
    Include(selectedScripts[i] || ".jsl");
So I have several sub scripts for my main script to call, I wanted to create a checkbox where the user can select which sub scripts to run (from Box Plot", "Box Plot_sublot_trend", "Box Plot_duration_trend", "Box Plot_FT1vsFT2", "Tabulation", "CDF&PDF11.) But no matter what I do I only get an empty window with the line " Select Scripts to run".
How can I solve this? Thanks!
Re: Check box won't show up in an input prompt input
There is no need to use For loop with check boxes. Display Functions (jmp.com) and Construct Display Boxes for New Windows (jmp.com)
This might not be exactly correct but gives an idea how to use checkboxes
cb = {};
	<<modal,
	V List Box(
			cb = Check Box(scripts)
		H List Box(
			Button Box("OK", cb << get selected),
			Button Box("Cancel")
If(nw2["Button"] == -1,
	Throw()
New Window("My report", V List Box(MyGraph(::yColName, ::xColName, ::xGroupName)));
Also do not use << close window on modal window, you will run into all sorts of issues.
As you are using << modal window you have to collect the results before it is closed
	<<modal,
	V List Box(
		Panel Box("Scripts", cb = Check Box(scripts)),
		H List Box(
			Button Box("OK", selectedScripts = cb << get selected),
and then remove selectedScripts = cb << get selected after the modal. You should also remove all the parts where you are trying to close nw2 as it is already closed when user presses OK/Cancel.
	<<modal,
	V List Box(
		H List Box(
If(nw2["Button"] != 1,
	// Throw("Cancel Pressed");
	stop();
// Close the script selection window
// Open a new window for the report
//New Window("My report", V List Box(MyGraph(::yColName, ::xColName, ::xGroupName)));
For Each({scriptname}, selectedScripts,
	script_path = scriptname || ".jsl";
	If(File Exists(script_path),
		Include(script_path)
		Write("\!N", script_path, " doesn't exist!");
cb = {};
	<<modal,
	V List Box(
		H List Box(
	Throw()
ARETI052
Thanks for the reply, I got that to work, but once I integrated the "<<Get Selected" function to my script, I got the Error "Not a Name" which I can't figure out what's wrong, any suggestions for solving this? Thanks.
cb = {};
    <<modal,
    V List Box(
        H List Box(
            Button Box("OK", Dialog(1)),
            Button Box("Cancel", Dialog(0))
// Check if the user clicked OK or Cancel
If(nw2["Button"] == 0, // If Cancel button is clicked
    Close(nw2);
    Throw()
// Collect the selected scripts based on checkbox input
selectedScripts = cb << get selected;
Close(nw2);
// Include the selected scripts using if statements
If(Contains(selectedScripts, "Box Plot"),
    Include("Box Plot.jsl");
If(Contains(selectedScripts, "Box Plot_sublot_trend"),
    Include("Box Plot_sublot_trend.jsl");
If(Contains(selectedScripts, "Box Plot_duration_trend"),
    Include("Box Plot_duration_trend.jsl");
If(Contains(selectedScripts, "Box Plot_FT1vsFT2"),
    Include("Box Plot_FT1vsFT2.jsl");
If(Contains(selectedScripts, "Tabulation"),
    Include("Tabulation.jsl");
If(Contains(selectedScripts, "CDF&PDF11"),
    Include("CDF&PDF11.jsl");
	<<modal,
	V List Box(
		H List Box(
	<<modal,
	V List Box(
		H List Box(
	stop();
ARETI052
Thank you so much!!
